Dual Revolution LED Relay Setup
mikenicola87
Posted: April 04, 2016 at 5:01 AM / IP Logged Link to Post Post Reply Quote mikenicola87
Relay Diagram
Hello, I am wiring dual revolution led lights that can be activated via toggle switch or a keyless entry system. Will this setup work? My main concern is reverse current from the constant positive power from the toggle switch bleeding into my relay chain. I'm hoping that the relay that is fed from the relay chain will protect the chain from this happening, but allow current to flow normally through once the 86 terminal is activated from the constant lead going into the relay chain.
If anyone has any other options or opinions, please let me know. Thanks!
Mikenicola87
