emergency light shut off
ydg1
Member - Posts: 15
Posted: June 18, 2003 at 7:04 PM / IP Logged
i install emergency lights port time.
one of the cars i was putting the light into. The owner ask if i could make the lights stay on when he comes to the emergency call.
when he get back in to the car after the emergency call, the light would go off automatically.
what would i need for this? (relay, diodes, ect.)
ydg1
xetmes
Silver - Posts: 586
Posted: June 18, 2003 at 7:09 PM / IP Logged
you could probably use a door triger idea so when he opens the door it turns off...
ydg1
Member - Posts: 15
Posted: June 18, 2003 at 7:49 PM / IP Logged
that would work when he gets out of the call i need something when he get back in.
copcarguy
Copper - Posts: 122
Posted: June 18, 2003 at 9:06 PM / IP Logged
How about triggering it off of the brake switch or the parking brake? I have never had anyone ask for this and I really don't know why he would want it but some guys really like the "gingerbread" I guess.
However, if he moves his vehicle to re-position it on scene then the lights would shut off when he may still want them on. Just a thought that you might point out to him.
R Jackson
Owner/Installer
TRM Emergency Vehicles
Information is advice only and should be confirmed with OEM or quality test equipment.
Boyertown, Pennsylvania
ydg1
Member - Posts: 15
Posted: June 19, 2003 at 8:03 PM / IP Logged
thank that should work.
how and what would i need to make it work.
never work with a brake shut off before.
xetmes
Silver - Posts: 586
Posted: June 19, 2003 at 8:28 PM / IP Logged
hey using the brake is a good idea
copcarguy
Copper - Posts: 122
Posted: June 19, 2003 at 8:46 PM / IP Logged
never done it before like I said but some sort of latching relay that would be released with the application of the brake pedal should do the trick, check out the relay section for more info.
R Jackson
Owner/Installer
ydg1
Member - Posts: 15
Posted: June 19, 2003 at 10:58 PM / IP Logged
Would it work in the like the way a remote starter that when you press the brake the engine would shut off.
over here the lights.
also did you ever do something like that. if you did could you send me a diagram may be i could change it for
what i need
ydg1
Sunday, October 12, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
