Flashing LED
techker
Copper - Posts: 70
Posted: December 20, 2003 at 8:17 AM / IP Logged
any body have a diagrame for flashing l.e.d?with or without a 555.
techker
Teken
Gold - Posts: 1,492
Posted: December 20, 2003 at 12:29 PM / IP Logged
http://www.discovercircuits.com/PDF-FILES/ac14fls.pdf
Flashing LED -- posted image.
The LED flasher circuits below operate on a single 1.5 volt battery. The circuit on the upper right uses the popular LM3909 LED flasher IC and requires only a timing capacitor and LED.
The top left circuit, designed by Andre De-Guerin illustrates using a 100uF capacitor to double the battery voltage to obtain 3 volts for the LED.
Two sections of a 74HC04 hex inverter are used as a squarewave oscillator that establishes the flash rate while a third section is used as a buffer that charges the capacitor in series with a 470 ohm resistor while the buffer output is at +1.5 volts.
When the buffer output switches to ground (zero volts) the charged capacitor is placed in series with the LED and the battery which supplies enough voltage to illuminate the LED. The LED current is approximately 3 mA, so a high brightness LED is recommended.
In the other two circuits, the same voltage doubling principle is used with the addition of a transistor to allow the capacitor to discharge faster and supply a greater current (about 40 mA peak). A larger capacitor (1000uF) in series with a 33 ohm resistor would increase the flash duration to about 50mS. The discrete 3 transistor circuit at the lower right would need a resistor (about 5K) in series with the 1uF capacitor to widen the pulse width.
Teken
Gold - Posts: 1,492
Posted: December 20, 2003 at 12:34 PM / IP Logged
Teken
Gold - Posts: 1,492
Posted: December 20, 2003 at 12:36 PM / IP Logged
techker
Copper - Posts: 70
Posted: December 20, 2003 at 1:29 PM / IP Logged
wow ok!thx is there a easyer way? and is this for 12 volts?
techker
Teken
Gold - Posts: 1,492
Posted: December 20, 2003 at 2:50 PM / IP Logged
The last two schematics are the easier of the lot to make.
If you do not feel up to the task to fabricate such a circuit, then I would suggest that you drop by any electronic store and purchase a 12 volt flashing LED unit that start from $2.99 to $8.49.
Very simple 2 wire hook up. Would take most people aprox. 5 minutes to hook it all up, and drill a 1/4" hole in the place required.
Regards
EVIL Teken . . .
xetmes
Silver - Posts: 586
Posted: December 20, 2003 at 3:31 PM / IP Logged
there is the classic 555 astable as well, but as Teken said its usually just easier to get a flashing LED if possible...
Wednesday, December 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
