stop lights/turn signals out
MikesMarine
Copper - Posts: 47
Posted: January 14, 2005 at 1:33 PM / IP Logged
'93 dodge shadow. the stop lights and turn signals just stopped working one day. any ideas? its not a fuse, and the the other lights all work. any idea where to start looking? is there a fuseable link or relay somewhere, or could this all be caused by one wire. ive looked and cant find anything
hurtado_roberto
Copper - Posts: 196
Posted: January 14, 2005 at 3:15 PM / IP Logged
My car has a fuse and a relay for the turn signals.  The relay's are usually in the engine compartment or next to the fuse panel.  If the relay is good then there's a flasher modual and the actuall turn signal stick that could be the problem.  I'm not sure about loose wires (maybe if you have an aftermarket electrical device that was unprofessionally installed).
Have you checked the light bulbs? You have stop lights on your car?  What poll did you crash into?
Poly Dollies
Thursday, March 12, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
