led conversion
scauntay
Member - Posts: 16
Posted: January 26, 2005 at 10:57 PM / IP Logged
i have a 1991 nissan 300zx and there is a LED conversion kit for the instument pannels in the car. they used flat top LEDs, thats about all i know. anyone know if i would need some resistors or somethin for that, and also where i would be able to buy some flat top LEDs. any help would be great.
thanks
cruelneo
Copper - Posts: 77
Posted: February 01, 2005 at 8:12 AM / IP Logged
if you want cheap leds i would look on ebay and do u hae a volt metter that will tell you if you need a risistor read the voltage at the plug if it is 3.5 you will be ok if not go to rat shack and tell them your voltage and then they will find the right resistor.
scauntay
Member - Posts: 16
Posted: February 01, 2005 at 5:10 PM / IP Logged
thanks, ill check out ebay. but if there are any stores online that sell the flat tops can you post up the site. thanks
Mad Scientists
Silver - Posts: 380
Posted: February 05, 2005 at 7:22 PM / IP Logged
hype8912
Member - Posts: 7
Posted: February 06, 2005 at 1:45 AM / IP Logged
www.superbrightleds.com
I've bought alot of LEDS from here.
scauntay
Member - Posts: 16
Posted: February 08, 2005 at 7:24 PM / IP Logged
thanks guys, ill check out the sites.
Wednesday, March 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
