96 nissan sentra m3 mirrors
96sentra
Posted: June 16, 2005 at 11:18 PM / IP Logged
I installed a set of m3 power mirrors for my 1996 nissan sentra gxe. the mirrors have blue L.E.D. turn signals on them but i have no clue where to hook them up to. i got the mirrors on fine and the power works. i know that i have to splice the power for the signal on the mirror to the signal wire on my car then ground it, but i can't find the signal wire that's close to the mirrors. i wanna know if anyone could get me a wiring diagram for the turn signals on my car. thanks in advance.
djvic03
Posted: July 18, 2005 at 4:51 AM / IP Logged
was it hard to get the base on for the M3 Mirrors cause i just got one and can't find a base that will fit.... thanks mate.
--djvic-in-da-house--
sunten1
Posted: July 24, 2005 at 8:57 PM / IP Logged
Theres 2 ways of going about this task
One is easier
1: (easier) You can go to the ticker in the front and tap the power wire. Then you can run wire into the mirrors
2:You could wire to the fuse inside your car. (this way you use less wire but its a bit more difficult unless you know what your doing.
sunten1
Posted: July 24, 2005 at 8:59 PM / IP Logged
One is easier
