2002 Dodge Ram, Neon Lic Plate Cover
km95b
Member - Posts: 6
Posted: December 31, 2002 at 12:19 PM / IP Logged
I installed a neon license plate cover on the front of my 2002 Dodge Ram and hard wired it directly to the right side parking lights.  It worked for a day and now the right side parking lights (and plate cover) have no power.  I checked the fuse and it's ok (left side still works fine).  Any idea's what happened?
Mr.Tech
Member - Posts: 21
Posted: December 31, 2002 at 10:52 PM / IP Logged
Check your wire it's might burn or may be you pinch somewhere...also if your light take alot current you should use relay .it's always better to use relay for those type of stuff
km95b
Member - Posts: 6
Posted: January 01, 2003 at 8:43 AM / IP Logged
How would I install this relay and where can I get it.
Kevin
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
