2000 accord brake lights
traxxxstar
Posted: June 29, 2006 at 9:29 AM / IP Logged
I've been working in the system in my accord and I don't know if it has anything to do with this but I found out my brake lights aren't working. all of the other lighting systems work (tail lights, reverse lights, headlights etc.) but when I hit the brake I get nothing. I've checked the all of the fuses for the lighting systems and replaced the bulbs for the brakes. Any suggestions, b4 I bring it the the shop?
Teamrf
Gold - Posts: 1,031
Posted: June 29, 2006 at 5:22 PM / IP Logged
Go to the brake switch see if the plug is still connected...also test the brake wire coming out of the plug as well.
~The Rookie~
Rookie of the year that is...
Don't let the smoke out of your equiptment..it doesn't go back in.
mjmadskillz
Member - Posts: 14
Posted: June 29, 2006 at 5:57 PM / IP Logged
You may have to replace the brake switch. Very Easy. If you dont know how some mechanics can do it for free. Ask around.
traxxxstar
Posted: June 30, 2006 at 12:01 PM / IP Logged
thanx for the help guys, I'll try that out
traxxxstar
Posted: July 19, 2006 at 8:35 AM / IP Logged
Just wanted to let you guys know it was the brake switch. I had to get my brakes done too so It's all getting done together 2day. thanks again for the help.
Monday, November 3, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
