head lights on, 1989 honda civic
nobles
Member - Posts: 11
Posted: May 16, 2007 at 8:22 PM / IP Logged
Yeah I always drive with my head lights on.
Problem is I always forget to turn them off. (no buzzer in my little honda)
I don't want to hook them up to the ign. switch, instead I want them to go off like a min. after I close the last door.
1989 honda civic hatch back
Thank you
Big Dog
Gold - Posts: 1,265
Posted: May 17, 2007 at 3:01 PM / IP Logged
This might work. You'll have to play with the resistor and cap to get the delay you want. A larger cap and a larger resistor will increase the delay.
Where it says "+12V from turn signal", connect this to ignition.
Where it says " 12V (+) to turning lamps", connect this to the headlight wire.
When you have it working, post your results please.
head lights on, 1989 honda civic -- posted image.
Prepare your future. It wasn't the lack of stones that killed the stone age.
Sunday, September 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
