12 volt led light
fredb38
Posted: May 24, 2007 at 9:16 PM / IP Logged
Is their a way to make a 12 volt LED light dimmer. I tried a resistor which had no effect.
I have a light that contain 16 LED lights. When 12 volts is applied to the light it is very bright as it should be. I was wondering if their was someway to tone it down.
Fred
KPierson
Platinum - Posts: 3,527
Posted: May 27, 2007 at 8:46 AM / IP Logged
You can do it with PWM (Pulse Width Modulation).
You should be able to do it with a resistor, too, but you won't get a smooth dimming.
Kevin Pierson
fredb38
Posted: May 27, 2007 at 12:01 PM / IP Logged
I have tried resistors with no effect. I tried 10 ohms, up to 50 ohms and it did not dim the lights at all. I measured the voltage as it did drop but still had no effect on the LEDs. The voltage started out around 12 volts and with the resistors I had it down to 10 volts but no effect on the lights.
Fred
KPierson
Posted: May 27, 2007 at 12:49 PM / IP Logged
You're going to need larger resistors then that, as you are trying to limit current.
If it is a 12vdc LED then has a resistor built in already.  I would try something starting at 1K ohms and working up towards 10K ohms.
For a project that I completed that needed two different LED brightnesses I used 470 ohms for 'bright' and 10K ohms for 'dim'.  These were standard non 12vdc LEDs though.
Kevin Pierson
integrapwnage
Posted: June 05, 2007 at 4:03 PM / IP Logged
Or you could goto radioshack and ask\look for a dimmer switch and hook that up so you can choose how dim or bright you want the LED's
