distorting amplifiers
bbuk
Posted: December 20, 2007 at 2:56 AM / IP Logged
hi,
this is my first post on this forum.
does any one know what could cause the amplifier (class d)  sound to become distorted after 6-8 months use.
i am using 0awg/4awg all round, big battery. the subs are wired correctly as well.
all the class d amps i use they work fine for a while and then the sound becomes distorted.
jmelton86
Gold - Posts: 1,228
Posted: December 20, 2007 at 3:15 AM / IP Logged
What is the model # of the amp? Model # of sub(s), and how they're wired to the amp. What vehicle? Where is the amp grounded? Where is it mounted (what to)?
And mostly, has the gain knob on the amp (and/or bass-boost) been turned up since it sounded fine?
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
bbuk
Posted: December 20, 2007 at 4:34 AM / IP Logged
i have 3 rockford fosgate 1501bd, alpine mrv 1507, kenwood ps401m all with the same problem.
the car is e36 m3 evolution with the battery in the boot. i've used the ground where the battery negative cable is attached.
i am using 2 jbl 1600, single 4 ohm voice coil. both are wired as 2ohm. the amp is mounted on the boot floor in front of the subs.
when i first set the gain up it sounded as it should. then the level of bass went down and sounds distorted.i turned it up a litte bit to see if it makes any differenc. i also turned up the remote bass to get more bass.
Platinum - Posts: 13,725
Posted: December 20, 2007 at 4:56 AM / IP Logged
For an amplifier, Vibration is the enemy.  Have you brought any of the amps to a repair shop to see what is happening to them?
bbuk
Posted: December 20, 2007 at 6:40 AM / IP Logged
if it was vibraton wouldn't the soldered joints become lose? there isnt' anything loose inside the amp.
my freind had a look but couldnt work out why it was distorting or as to why it happened.
DYohn
Platinum - Posts: 10,741
Posted: December 20, 2007 at 8:24 AM / IP Logged
If you have tried three different amps all showing the same problem, chances are it's not the amp.  Get your sub checked out.   You may also want to check system voltage and ensure it is not dropping to low, and ensure it is DC and you haven't fried a rectifier in your alternator.
bbuk
Posted: December 20, 2007 at 9:06 AM / IP Logged
i have replaced the subs and the checked the tinsels etc.
the battery voltage is around 12.5 and around 13.8 -14.2 volts with the engine started.
on a hard bass not voltage goes down to 11 and then pops back up.
if the rectifier was fried what would the symptons be?
DYohn
Posted: December 20, 2007 at 9:54 AM / IP Logged
A fried rectifier can exhibit many different problems, including strange amplifier behavior.  You can have your charging system checked and know instantly.  It is also possible your subwoofer enclosure is sized wrong and causing the speaker voice coil to overheat, or the speaker has a partially separated voice coil that is causing distortion after it heats up.  A speaker can appear to be fine sitting cold on the bench but actually be fried.  This is especially possible if the problem exhibits after a time operating and not immediately at turn-on.
bbuk
Posted: December 20, 2007 at 10:24 AM / IP Logged
if the rectifer was knackered wouldnt it cause other electrical components to fail such as bulbs and other gadgets.
do u think its my charging system? if it is why is it destroying the sound output on the amp.
would i be able to test the aleternator my self with a multimeter.
are there any mesaures i can take so this doesnt happen to my new amps.
Posted: December 20, 2007 at 8:03 PM / IP Logged
Vibration sometimes breaks the legs of the transistors inside the case of the transistor.  The transistors are clamped down to the heat sink.  Nothing breaks loose and falls off.  But the legs do break causing all kinds of faulty operation.
Wednesday, March 18, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
