1993 camaro with bose audio problem
jayo
Posted: December 25, 2007 at 12:35 AM / IP Logged
Hi,
I have a 1993 Camaro with factory bose, I hate it. So I got a Pioneer DEH-P6900UB HU for my car. Well I can't seem to find the correct wiring diagram for bose. Also, when I cut the original harness off, dome light went out, and the alarm for your lights doesn't work. I know it's not a fuse because I checked every one, and happened to touch just one certain wire and they came back on for a second and went off. If you have any advice/help that would be great.
Thanks,
James
519civiconair
Copper - Posts: 50
Posted: December 27, 2007 at 12:38 AM / IP Logged
its either Gray or Brown wire check with Dmm and hook up as necessary possibly both as one is for the Dimmer probably (+) changing voltage with the dimmer switch and one is illumination probably (-) and is somehow tied in to the doorpin triggers hope this helps
F.B.S.S air ride is the only way to roll
Saturday, November 8, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
