battery died could it be how i wired?
bmw850
Posted: January 07, 2008 at 12:34 AM / IP Logged
I just put a Pioneer DEH-P590iB in a 91 bmw 850i
I have attached pictures from the manual as well as a picture of the wiring harness. My battery died and i'm worried its because I wired the harness wrong. The car has a factory amp and originally when I wired the harness I did not connect the blue/white wire from the Pioneer harness to the BMW harness because there was only a solid blue wire left after I connected the rest of them.
battery died could it be how i wired? -- posted image.
I was getting the radio to power up but no sound. So I then connected the blue wire that says Power amp + to the blue/white which is the connect to system control terminal of the power amp wire on the pioneer. Could this be causing the batter to drain because I read this in the manual.
This is what I found for the wiring on the 850
The following numbers correspond to the harness that plugs into the BMW radio. Each wire has a number that routes to a certain location.
Documentation came from a 1994 manual pertaining to a BMW 8 HiFi 10 speaker system. I would double check wiring by using a light tester.
Radio
Pin#
1 = Speaker LF+
2 = RF+
3 = LR+
4 = Telephone Transceiver
5 = Accessory Power
6 = RR+
7 =
8 = LF-
9 = Battery
10= Body Electronics Module
11= RF-
12= LR-
13= Light Switch
14= RR-
15= Ground
16= Antenna Amplifier
17=
18=
19=
sedate
Silver - Posts: 1,173
Posted: January 07, 2008 at 7:04 AM / IP Logged
I'm not really a wiring guru, but it is certainly possible that you wired it in such a way that keeps some componet sipping on the battery constantly.
Wish I could tell ya what to do..
bmw850
Posted: January 07, 2008 at 7:34 AM / IP Logged
well that didnt help anyone else a guru? lol
audioman2007
Copper - Posts: 580
Posted: January 07, 2008 at 9:59 AM / IP Logged
What color wire is pin 16?
bmw850
Posted: January 07, 2008 at 3:14 PM / IP Logged
blue withut the line
jice
Member - Posts: 9
Posted: January 07, 2008 at 3:37 PM / IP Logged
Yeah...it sounds like something is staying on ...or the Head Unit is never turning off the Amp (Check the remote wire to the amp?).
Also make sure you have the 12v wires wired correctly...the yellow wire is usually your constant on (For the Head unit memory) and there will be another 12v wire for power when the ignition is turned, ACC feed (ie +12V when key is turned to ACC) Make sure tehy're not swapped or spliced into the same feed.
Make sure the ground is good (clean ground on bare metal)
bmw850
Posted: January 07, 2008 at 6:07 PM / IP Logged
nothing wrong with battery. Turned out that there is a switch in the trunk that turns off the power to the car meant for long vacations to save battery. My trip to costco and a full trunk tripped the switch which I knew nothing about. LOL
