advice on this system setup.
thumpinbass
Member - Posts: 10
Posted: January 28, 2008 at 3:24 PM / IP Logged
Hey guys,   first time poster, long time reader.
I'm getting to start my system in my avalanche and wanted to know what you guys thought, good, bad, suggestions, comments.
4 - Kicker 07CVR10-4     10" Dual 4 ohm 800 watts wired together in 2 ohm.
Kicker 06zx1500.1          1500 watt RMS Class D mono to power the subs
Kicker 05KS652 6.5" Components for the fronts
Kicker 05KS65 6.5" 2-way for the rear doors
Kicker 06ZX350.4    350 watts x 4 channels
This will all be connected to a CarPC going to a Kicker KX2 2-way crossover to both amps then to speakers.
What do you guys think?  I'll take any advice.  I thought about upgrading to the 2500.1 amp but thought it might be too much.
Let me know.
Allen
Alpine Guy
Platinum - Posts: 2,478
Posted: January 28, 2008 at 5:06 PM / IP Logged
That should sound pretty good. Are you going to be making a box out of the midgate?
big sexy lac
Copper - Posts: 153
Posted: January 28, 2008 at 6:29 PM / IP Logged
Yup I agree that system is gonna be loud, are u gonna upgrade the batt?
well?
jmelton86
Gold - Posts: 1,228
Posted: January 28, 2008 at 6:41 PM / IP Logged
Loud, that's for sure.
You'll need a HO (high-output) alternator. Your factory one is either 105 or 145amp. Oh, and the Big3.
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
thumpinbass
Member - Posts: 10
Posted: January 28, 2008 at 7:29 PM / IP Logged
Yes to everyone of you.
Along with the stereo, the following will also be done.
Big 3 upgrade, Replace stock battery with Optima Red Top, Add a 2nd battery (Optima Yellow Top), and upgrade alternator to probably a 250amp HO.
The subbox will replace the midgate.
Allen
jmelton86
Gold - Posts: 1,228
Posted: January 28, 2008 at 8:10 PM / IP Logged
Sounds good. But, use 2 identical batteries. Within 6months old of each other. Redtops are better for car audio, and less expensive.advice on this system setup. -- posted image.
Otherwise, looks good.
Big3 in 1/0G
1/0G to GTO14001
Alpine Guy
Posted: January 28, 2008 at 9:02 PM / IP Logged
Where are you going to be putting that extra battery? I have an Avalanche too as you can see in my signature, an extra battery would help me tonnes for at shows.
greenbroncoguy
Copper - Posts: 299
Posted: January 29, 2008 at 11:13 AM / IP Logged
Good advice here; you really want to use 2 batteries of the same make and model, and ideally of the same age. This will help minimize the chances of one from being weaker and pulling a charge from the stronger one...
Oh, and sounds like your system is gonna slam byt the way advice on this system setup. -- posted image.
