subwoofer vibration problem
m4a1rifle
Posted: February 23, 2008 at 12:23 PM / IP Logged
Recently bought a RF P1 12", it is causing annoying vibration noise to the metal plate inside of car boot. Now my woofer is facing the boot door, so if my woofer facing a different direction, will it soften or cancel the vibration on the metal plate?
because i plan to make a new box if it can solve the problem.
location of the metal plate:
subwoofer vibration problem -- posted image.
aznboi3644
Gold - Posts: 2,600
Posted: February 23, 2008 at 1:27 PM / IP Logged
Try filling the gap between the trunk lid skeleton and the outer skin.
After that some sound dampening mat will help. You can also fill in the voids with expanding foam
rrcustom
Copper - Posts: 87
Posted: February 23, 2008 at 6:42 PM / IP Logged
Agreed. Expanding foam is usually the best and the quickest fix. Be careful when applying...it does expand ;-)
Platinum - Posts: 13,726
Posted: February 23, 2008 at 8:05 PM / IP Logged
As stated earlier, that stuff really does expand.  It will have no problem reshaping the outer skin of your boot.  So if you do go this route, you really need to do a few test drops of it just so you know how much it expands.
m4a1rifle
Posted: February 24, 2008 at 11:10 AM / IP Logged
is it true that if apply expanding foam to the boot door it is impossible to reshape the metal if it got bump cause by accident?
hungryandfat
Member - Posts: 15
Posted: February 24, 2008 at 12:26 PM / IP Logged
Thats something I wouldnt worry about. Odds are if you are in an accident and it causes damage, most likely the whole panel will be replaced. If its not that bad then it would be minimal work for a panel like that. Most minor repairs are done from the exterior of the panel anyways. But access to the rear of the panel makes it a little easier.
