engine noise in civic ppp
maple50175
Posted: April 08, 2008 at 12:57 PM / IP Logged
I have an 02 civic LX and I have SERIOUSLY annoying engine noise.
I have an Alpine Headunit, Infinity 4 chan amp, Infinity speakers, and 2 Kicker comp CVR subs.
I just replaced the speaker wiring hoping it was because i used cheap wire but no, its still super loud and annoying.
If i'm listing to the music with the car off it sounds fine. When i start the car and turn the music on but keep the headunit on i hear like a loud da da da da da da then when i drive it gets louder or whatnot.
It's really annoying. I never had this problem. Why is it doing this?
let me know!
klctexas
Copper - Posts: 111
Posted: April 08, 2008 at 1:10 PM / IP Logged
Are your RCA cables next to your power wire? They should be on different sides of the car...
Soldier: This is the worst part. The calm before the battle.
Fry: And then the battle is not so bad?
Soldier: Oh, right. I forgot about the battle.
haemphyst
Platinum - Posts: 5,059
Posted: April 08, 2008 at 3:26 PM / IP Logged
That's a fallicy. I've run all my wires together for YEARS, and I have never had it PROVEN to me that that combination can cause noise. 99+% of the time it can be narrowed to a bad battery or bad ground.
Check this thread out...
The spiz has spoken! LOL (Actually I only added that sentence so I can easily find this thread to more easily find the LINKED thread - as that one never seems to come up in any searches.)
klctexas
Copper - Posts: 111
Posted: April 08, 2008 at 3:31 PM / IP Logged
Well, it might be different for each application. I had my RCAs slide next to my power wire, and I got a fuzzy sound from them, but the sound did not increase with the volume. Instead, it drowned out the noise, but it was annoying at low levels. When I moved the RCAs back where they go (and ziptied them), the noise was gone. Just what happened to me.
Platinum - Posts: 13,726
Posted: April 08, 2008 at 7:38 PM / IP Logged
I too have never seen a problem running RCA and power on the same side of the car.  I zip-tie them together.  I think the same person that said this causes a problem also said that a capacitor would stop your headlights from dimming.
daboss593
Copper - Posts: 154
Posted: April 09, 2008 at 1:13 PM / IP Logged
im a noob but the few installs ive done, and helped on. same thing ran them together. almost every time its a ground. or some idiot brings his car in with 4 diff grounds for 4 amps.....idiots.
OWWWWWWWWWWW you said you discharged the cap!
Posted: April 09, 2008 at 8:09 PM / IP Logged
Hey  what did I do?
daboss593
Copper - Posts: 154
Posted: April 10, 2008 at 6:18 AM / IP Logged
lol not you the customer.engine noise in civic ppp -- posted image.
