battery isolator, 96 silverado
s10riddinlow
Posted: May 07, 2008 at 7:26 AM / IP Logged
im running a stinger isolator in a 96 chevy silverado for the 4 back batterys. im not sure how to wire this thing in. has ne one installed one before. thanks guys
jvillefinest
Copper - Posts: 255
Posted: May 07, 2008 at 10:04 AM / IP Logged
Run power from the front battery to a fuse to the isolator then out the isolator to another fuse to the secondary batteries. Then starter power to one of the smaller lugs and ground to the other smaller lug make sure it makes a thud when you turn the key forward and you should be good.
2007 Acura TSX
SQ setup in the works
Saturday, December 20, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
