does preamp outputs have watts?
iwanttobang
Member - Posts: 44
Posted: May 20, 2008 at 9:57 PM / IP Logged
So would if my car stereo is 25x4 rms. So if I use the preamp out puts into a 25x4 amp will my total amps per speaker be 50 watts?
Basically when using the preamp outputs from the deck does the system still sees the deck power?
DYohn
Platinum - Posts: 10,741
Posted: May 20, 2008 at 10:07 PM / IP Logged
No.  The power rating of an amplifier is what it can deliver into a speaker.  A head unit is no different, the power rating is for the built-in amplifier.
stevdart
Platinum - Posts: 5,816
Posted: May 20, 2008 at 10:10 PM / IP Logged
No it doesn't.  The deck acts as a preamp when the speakers are connected to a power amp.  It amounts to this:  an amplifier performs only when it is loaded with impedance at the input stage;  no speakers to provide the load = no power output.
If a deck still had speakers loaded on it even when supplying a signal to a power amp, it would provide power to only those speakers.  But it still wouldn't provide power to the amp.
iwanttobang
Member - Posts: 44
Posted: May 21, 2008 at 2:07 AM / IP Logged
grrr..
I bought a Alpine MRPF240 4 Ch. 360 Watt Amplifier(which I just added . I swapped out my junk sound storm amp/ Alpine is much clearer). I was under the impression that the watts of my deck would add with the watts of the amp as well..
Well looks like when I buy a sub woofer I'm going to to to buy a more powerful amp for my highs right? The amp only dies 40x4 RMS @ 4 ohms
and 50x4 @2ohms
jmelton86
Gold - Posts: 1,228
Posted: May 21, 2008 at 2:25 AM / IP Logged
I have the exact same amp for my front stage. I doubt you'll need to upgrade from that. That is, if you have decent front speakers...
2013 Kia Rio -90a alternator
DDX470HD GTO14001 GTO1014D (x3)
Big3 in 1/0G
1/0G to GTO14001
iwanttobang
Member - Posts: 44
Posted: May 21, 2008 at 3:04 PM / IP Logged
Yeah i have Kicker front and rear speakers. The front speakers have separate tweeters attached
