kicker amp/sub cutting outwhy?
remusrm
Member - Posts: 32
Posted: June 25, 2008 at 2:55 PM / IP Logged
I have a kicker 400.1 amp(rated at 487) and 1 kicker solobaric L5 (2006 Model). Got them all new. When I play certain songs or even when loud it just turns off, or rather the amp gets the RED light, I assume protected mode. Why is that? it wired to be at 2ohm stable and it works just fine. I have a pioneer DEH-2900mp with HP at 80hz LP at 80hz while the gain is at -10 from the stereo, bass even at 0. The amp is set to play up to 100hz as indicated on the knob, and gain at less then half. The bass boost is at 0. What can cause this? The ground and wires are fine. The power wire it might be less then the desirable gauge, but work fine.
djmostry
Member - Posts: 14
Posted: June 25, 2008 at 3:15 PM / IP Logged
test the power and ground whit a volt metter and your car runnig it has to be on 13+- volt if is good maybe 1 of the coils of the solobaric is bad
how many ohms is the speaker and how do you conect it?
pablo
remusrm
Member - Posts: 32
Posted: June 25, 2008 at 3:26 PM / IP Logged
the speaker is 2 ohm, and is wired as in the specs, to make the sub drop to 2 ohm.
djmostry
Member - Posts: 14
Posted: June 25, 2008 at 3:46 PM / IP Logged
ok if the speaker is a dual 2 ohms
you canot makeit drop at 2 ohms
if you do + and + and - and - togeter
you will drop it to 1 ohm and that is no good for you amp
if you did series wirring is a 4 ohm load safe for the amp
you canot make a dual 2 ohm speaker 2 ohm unless you only use 1 voice coil
pablo
DYohn
Moderator - Posts: 10,741
Posted: June 25, 2008 at 7:14 PM / IP Logged
One or more of the following is happening:
1. Your gain is too high
2. Your impedance load is too low
3. You have a bad ground connection
4. Your vehicle's electrical system voltage is dropping too low
How did you set your gain?  How is the speaker wired?  What is the exact model number of the amp and the speaker(s)?  How do you know the "ground and wires are fine"?  What is your ground return resistance?  What is your system voltage when the amp shuts down?
Tuesday, November 4, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
