subs, using 4 and 8 ohm together?
jjfne
Member - Posts: 7
Posted: October 28, 2008 at 6:55 PM / IP Logged
what do you think about using a 4 ohm sub and a 8 ohm together,  someone gave me the 8ohm, didnt know if it would be worth hooking it up
Jon
stevdart
Platinum - Posts: 5,816
Posted: October 28, 2008 at 7:47 PM / IP Logged
It depends on what amplifier you are hooking them up to.  In parallel, they would make an impedance of 2.67 ohms.  Of course, you could use two amps...but I wouldn't guess that someone gave you an amp as well.
The impedance of a speaker determines the power it gets.  If, for example, a mono amp (capable of a 2 ohm load) is powering the pair, the 4 ohm speaker would get twice the power as the 8 ohm.
If you're thinking that it might make an improvement to your sound system, shelve the idea altogether.
jjfne
Member - Posts: 7
Posted: October 28, 2008 at 8:20 PM / IP Logged
has several amps, but using my 500/1 one a jl audio w1 4 ohm,  was givin a 12 w1 8 ohm, that amp should be fine, just checking to see what people thought
Jon
DYohn
Platinum - Posts: 10,741
Posted: October 29, 2008 at 11:39 PM / IP Logged
Saturday, February 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
