kicker l7 12 ported enclosure
kulavc3
Posted: December 17, 2008 at 2:28 AM / IP Logged
Hello, I have a Kicker L7 and had a few questions on the ported enclosure.
1. I wanted to have it to have dual round ports for semetry in the trunk, and the trouble that I am getting at is the calculator on the site provides the port length for 1 port but I was wondering how to configure it so that I could have 2 ports.
2. The box is going to be ~2.75 cf and I was tuning it around 40 hertz. I was also going to use  3.75 inch dia ports
Thanks for the help and any input if this box design would have good SQ and SPL combined would be a great help
aznboi3644
Gold - Posts: 2,600
Posted: December 17, 2008 at 6:20 PM / IP Logged
I'd drop it down to 2.5 cu ft net with two 4" diameter round ports 19" long. Tuning approx. 35Hz.
Custom Enclosure Design
kulavc3
Posted: December 18, 2008 at 6:04 PM / IP Logged
alright thanks that sounds great....and may I ask how did you come to the conclusion of getting to 35 Hz?  How did you make your calculations for the two ports?
aznboi3644
Gold - Posts: 2,600
Posted: December 19, 2008 at 1:40 PM / IP Logged
yes I calculated the port lengths with the volume and port area. 35Hz will be a lot better all around daily than 40Hz.
and that is 2.5 cu ft NET not including port, sub, and bracing displacement.
Saturday, April 11, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
