two batteries hook up
juliojr@614
Member - Posts: 6
Posted: December 21, 2008 at 8:20 AM / IP Logged
Can some draw up a pic for the hookup of 2 batteries to 2 ampz how is this done
Julio C. Ortiz Jr
CutDog504
Silver - Posts: 643
Posted: December 21, 2008 at 8:55 AM / IP Logged
There are many different ways to wire it up. It would be best if you explain what you want to use this setup for "two amps" is pretty vague. Is it two 100 watt amps, or 2 1500 watt amps?? Are you trying to wire in 2 additional batteries (3 total) or 1 extra battery(2 total)? Is this for a daily driver? Or is this a show or competition vehicle? Will you be playing the stereo with the car engine not running? And if so, will it be for extended periods? You need to take all of this into account to determine what will be the best wiring setup/configuration for your particular application.
juliojr@614
Member - Posts: 6
Posted: December 22, 2008 at 12:38 AM / IP Logged
2 batteries total 800 watt amp 4 the door and front and 1200 4 the bac with 2 tv mon.
Julio C. Ortiz Jr
