bcm location, 07 tahoe
jtaguacta
Posted: January 01, 2009 at 9:42 PM / IP Logged
I need help tryin to locate the BCM on my '07 tahoe. upgraded to an aftermarket head unit and need to tap into the BCM so that the steering wheel controls will work. I'm using the axxess aswi-ps universal steering wheel control interface and cannot locate the BCM or which wire i'm supposed to tap into any help would be great
jt
Steven Kephart
Platinum - Posts: 1,737
Platinum spaceThis member has been recognized as an authority in Mobile Audio and Video. Click here for more info.spaceThis member consistently provides reliable informationspace
Posted: January 01, 2009 at 10:19 PM / IP Logged
You will have to drop the dash panel below the steering column to get to the BCM. You will see it to the left of the steering column. All the steering wheel control adapters I've used had wiring information to help you find the correct wire. I recommend that you look through the instructions to find it.
