replacement speakers delco bose 93 camaro
lt1redz
Posted: January 28, 2009 at 11:26 AM / IP Logged
I need to replace the door speakers and the only rear speaker.Can anyone suggest a brand I can search for.I believe they are 4ohm.The cone size is 5 1/2" The screw are spaced 6 1/8 6/1/4..Or should I junk the delco bose system and what would recommend. Thanks for the help.
sparkie
Platinum - Posts: 2,061
Posted: January 28, 2009 at 4:40 PM / IP Logged
The Bose speakers aren't 4 ohm. If you don't replace them with Bose speakers, then scrap everything including the radio and start over. The factory Bose radio has no amp in it and each speaker has it's own amp. The Bose speakers are usually 1 or 2 ohms.
sparky
Monday, April 6, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
