2007 mazda3 stereo replacement
mikedero08
Member - Posts: 6
Posted: February 16, 2009 at 9:56 PM / IP Logged
I have a 2007 Mazda 3 with a fully integrated stereo, for lack of better words. It has a Bose sound system which sounds pretty good but prevents me from installing sub woofers because the head unit doesn't support it. Now in a normal situation you could just remove the stock head unit and replace it with a new one. However, as far as I know, this is not possible with my car without(in my case)completely destroying the interior. What Im getting at is, is there anyway I can still hook up sub woofers without changing out the head unit. My buddy said there was some kind of filter I could use to run the speaker input directly to an amplifier while still keeping quality sound through the woofer. I don't know about half the stuff he says but I could be wrong. Any ideas? Thanks.
soundnsecurity
Gold - Posts: 2,720
Posted: February 16, 2009 at 10:14 PM / IP Logged
of course, what you need is called a line output converter. it steals a signal from your existing speaker wires and gives you a set of RCA outputs that can be used by any amp. the easiest place to install one of these is at your rear speakers, this will also save you some money by not having to buy a long set of RCAs to reach all the way to the front to the back where your amp will most likely be.
Platinum - Posts: 13,726
mikedero08
Member - Posts: 6
Posted: February 17, 2009 at 5:03 PM / IP Logged
Alright, so if I were to do as [i am an idiot] showed me, I would be losing the display that shows my climate control information and all that jazz, correct?
Posted: February 17, 2009 at 5:54 PM / IP Logged
Description
Mazda 3 04-Up (Click on part for more info)
2004 - 2008
Product Specifications
***********  -Will retain display in 2006-Up vehicles **********
**********  -Includes display rentention brackets ************
  • -Includes display replacement pocket
  • -Metra's patented Snap-In ISO support system
  • -Recessed DIN mount
  • -Under radio pocket
Sunday, April 26, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
