92 Civic LX install
cipro
Member - Posts: 6
Posted: March 22, 2003 at 1:58 PM / IP Logged
im trying to install my Clarion system into my 92 Civic.  The Head Unit is already installed.  The problem that I am having is I dont know how to get the wire from the battery to the Amp.  I originally had this installed in a 93 jetta and that car had a hole in the fire wall where all car wires were run so I just ran my wires through there as well.  In this car i cant find anything like that.  I dont want to drill through the firewall, there has to be another way.
On top of th is I would like to know the best way to run the wires once inside the car (the amp will probably be in the trunk).
Thanks for the help.
cipro
Member - Posts: 6
Posted: March 22, 2003 at 3:03 PM / IP Logged
One thing I forgot to add....I guess it should be obvious but I should probably point this out.  I know that there has to be a gromit somewhere on the firewall where all the wires got into the car from the engine.  I just cant find it.
Im just hoping that someone has done an install on a civic and knows approx. where this is.
willestl
Posted: March 23, 2003 at 12:58 AM / IP Logged
it's underneath the glove comparment....there should be a little rubber patch that is covering it...if you peel that off then you should see your firewall hole..stick something through it and make sure you can see it when you look under your hood
