us amps md.1d?
dohckiller808
Member - Posts: 28
Posted: May 28, 2009 at 12:23 AM / IP Logged
i just got mine in the mail.... not installed yet.
Did US Amps go down hill???
the gutts look like something out of a cheap amp. the feel of it and everything screams cheap!
this amp supposed to replace my MTX 942.
you guys think its worth the switch?
150SPL musical in a civic coupe
fiberglasslvr
Copper - Posts: 116
Posted: May 28, 2009 at 1:14 AM / IP Logged
I use U.S. amps on occasion and have not noticed anything bad about them, they have not given me any problems. but I also have not compared the guts from the new amps to the old ones,so I cant give you a definite answer on that. In my opinion I think you should be just fine with the MD1D.
good luck
in process of changing everything
dohckiller808
Member - Posts: 28
Posted: May 28, 2009 at 1:38 AM / IP Logged
it has a look like the cheap lanzer amps. its real light and stuff. i dunno... ill hook it up and see. it says its rated at 1200rms @ 1 ohm 14.4 volts. but by looking at it, 1200 peak seems more realistic. this is bumming me out.
lspker
Silver - Posts: 503
Posted: May 28, 2009 at 9:26 PM / IP Logged
It's the mid line stuff, works and makes good power, clean.  The AX line is heavy.
