radio/dimmer swirch wiring problem
gumbydamnit
Posted: March 26, 2003 at 9:13 PM / IP Logged
i installed a cd player a while back and a couple months or so after doing so, i have to turn the dimmer switch up and turn on the dome light(part of the swich, 93 caprice) in order for the sound to come out of the speakers. when i turn on the dome light i can push the dial back down to the low dimmer/domelight off possition and the dome light stays on and dim..
i checked the stereo wiring and it IS right, and i took the dimmer dial switch out and cleaned it and that didnt help, but when i took the fuse out for the dimmer switch then it was fine.
but i needed it in for door locks so i put it back in and took the dome light bulb out.
any help would be greatly appreciated!
Thanks.
Graham.
mafba@hotmailNOSPAM.com
esmith69
Gold - Posts: 1,511
Posted: March 26, 2003 at 9:19 PM / IP Logged
disconnect and tape up the dimmer and/or illumination wires from the radio's harness and see if that fixes the problem.
wrencher_25
Copper - Posts: 101
Posted: March 27, 2003 at 2:01 AM / IP Logged
THAT MAKES SENSE.......
You don't need the dimmer to be hooked up for the radio to work!!! Heck, I don't even have mine hooked up right now! Why didn't i think of that. Good one Esmith.
Andrew Weitzel
MECP First Class Installer
gumbydamnit
Posted: March 27, 2003 at 10:57 AM / IP Logged
im sorry i didnt mention it but the dimmer IS disconnected. i capped it. it doesnt connect to the radio. so thats not it, thats the Crazy part, its not even hooked up!
Thanks!
graham.
esmith69
Gold - Posts: 1,511
Posted: March 27, 2003 at 7:06 PM / IP Logged
well poop!....okie back to the drawing board for this one...gotta think about it a lil more and do some research but we'll figure it out eventually!
Friday, February 13, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
