can this be done? 1963 impala upgrade
mobileavc
Member - Posts: 27
Posted: July 30, 2009 at 10:25 AM / IP Logged
Good morning guys,
I need a little help here - I've searched online and through our archives for some direction on this topic. Here's the situation...
Customer has a 1963 Impala with factory OEM AM/FM radio. It uses a single (+) wire speaker output. The front speaker's negative is direct to chassis ground. The factory radio is rated for a 10-ohm load to the original front mono speaker. Here's the question:
Customer brought a pair of Pioneer 4-ohm speakers to me to install in the front/rear speaker locations. Although I am fairly sure that an 8-ohm nominal load won't kill the OEM radio (wiring the pair of Pioneers in series), WILL THE SERIES WIRING / NEGATIVE TO CHASSIS GROUND cause a dead short or fry the radio?
Basically, the flow would be like this: (+) out from radio to (+) of speaker 1, (-) of speaker 1 to (+) of speaker 2, (-) of speaker 2 back to radio and tied to ground. On my DMM, I still get an impedance of ~8 ohms when this is all hooked up (but not to the radio), but am I asking for a small puff o' smoke from the radio if I continue as described?
Anyone with experience in these older radios, please chime in ASAP! Thanks!
DYohn
Platinum - Posts: 10,741
Posted: July 30, 2009 at 12:13 PM / IP Logged
mike swanson
Copper - Posts: 290
Posted: July 30, 2009 at 12:25 PM / IP Logged
Is this the same car we were talking about leaving the factory radio in and addin a new radio under the factory in this forum?
anyway I wouldnt do it. the old radios are very weak.
You can order a factory replacement 10ohm for that car
Just like amps if you go below you will see smoke.
Here was the other post
https://www.the12volt.com/installbay/forum_posts.asp~TID~115126~PN~2
mobileavc
Member - Posts: 27
Posted: July 30, 2009 at 2:15 PM / IP Logged
Hello,
No, different post and OP.
Customer is intent on using the original and fully-functioning radio - I just wanted to make sure that I was safely wiring up the new speakers correctly.
Thank you for the quick responses.
Erik Quick
Mobile A/V Creations
