rear woofers
nokie1
Member - Posts: 20
Posted: August 19, 2009 at 6:32 PM / IP Logged
when i turn my head unit on my woofers start bumping,even when the volume is on 1. i have changed the rca wires,ground and remote wires. what else could be the problem? thanks
Platinum - Posts: 13,725
Posted: August 19, 2009 at 7:17 PM / IP Logged
There should be a knob on the amp labeled either Gain or Sensitivity.  Have you tried turning that knob all the way CounterClockWise?    Does it also have horrible engine noise?  Is it a Pioneer radio?
djrankin004
Copper - Posts: 154
Pioneer head unit?
nokie1
Member - Posts: 20
Posted: August 20, 2009 at 12:12 AM / IP Logged
no engine noise,and its an  kenwood radio.turned the amp all the way down and the bumping goes away.
Posted: August 25, 2009 at 10:44 PM / IP Logged
Can you reach your desired listening level with the gain all the way down?
DYohn
Platinum - Posts: 10,741
custombass
Copper - Posts: 54
Posted: August 26, 2009 at 11:53 AM / IP Logged
Any in-line signal processors?
