active crossover and passive crossover
snowdeath
Member - Posts: 32
Posted: September 30, 2009 at 12:27 AM / IP Logged
Right now I'm in the process of designing / installing a car pc project in my mustang. I currently have an audiocontrol 2xs active crossover splitting the audio signal from the sound card at 90hz. The low half goes to the sub amp and the mid/highs go to the other amp. Now I do not have a separate amp for tweeters so I have the mid/high signal passing through the amp to passive crossovers set at 3500hz. I would like to know how the active and passive crossover points are affecting each other if any?
I realize that when you use two active crossovers, it changes the crossover freq and db/octave, but I have no clue how the active and passive xovers are affecting each other.
Thanks!
DYohn
Moderator - Posts: 10,741
Posted: September 30, 2009 at 4:48 PM / IP Logged
They are not affecting each other.
haemphyst
Platinum - Posts: 5,059
Posted: September 30, 2009 at 6:06 PM / IP Logged
They will only affect each other's responses if they are stacked... meaning running at the same or close to the same crossover frequency.
Between 90Hz and 3500Hz, they are so far apart, they don't even know the other one is there.
snowdeath
Member - Posts: 32
Posted: October 01, 2009 at 3:12 AM / IP Logged
awesome! That is exactly the information I was looking for! Thanks!
Tuesday, October 14, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
