Posted: October 03, 2009 at 6:54 PM / IP Logged
Posted: October 03, 2009 at 7:25 PM / IP Logged
Posted: October 03, 2009 at 8:18 PM / IP Logged
Posted: October 05, 2009 at 7:58 AM / IP Logged
Posted: October 07, 2009 at 3:58 PM / IP Logged
Posted: October 08, 2009 at 11:08 AM / IP Logged
Posted: October 08, 2009 at 3:08 PM / IP Logged
Posted: October 08, 2009 at 3:37 PM / IP Logged
Posted: October 11, 2009 at 2:49 PM / IP Logged
Posted: October 24, 2009 at 4:27 AM / IP Logged
Tuesday, December 2, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved • Privacy Policy & Use of Cookies
Okay so I'm having a lot of trouble getting the top to fire up.
The bottom amp is a 4 channel Interfire amp that runs 175 X 2 into 4 ohms which i have wired up to the 6x9's.
The top amp is a Bazooka amp 70 watts x 2 into 4 ohms which i have wired to the subs. This amp i cannot get to work (Blue circle)
My signal source is an ipod (represented by the PSU koozie). The yellow circled source is output to the car's speaker system, the pink circled source is output split to the two amps. Now here is the weird issue at hand.
-The interfire amp works regardless, when I fire it all up it's on it pushes the 6X9's great and has no hitches regardless of what goes on.
-When I just run signal from the ipod to the amps and don't include the car system (yellow input unplugged) both the bazooka and interfire amps run fine at full strength.
-When I plug in the car system to the ipod source the bazooka amp's protect goes from green to red after about 1/3 volume added to the car system and cuts.... the interfire runs fine.
-When I pull the power from the interfire and have just the bazooka running it has the same issue. The moment i try to run the bazooka with the car system as well, the protect goes off when i reach about 1/3 volume on the car system.
I'v tried adding another ground to the battery and adding another ground to the bazzoka amp. I have reached the extent of my knowledge and internet search ability on this one and could use some help on this one.
Thanks in advance!
~Zack
2001 Pontiac aztek
