problems with audi
markmorb
Posted: October 07, 2009 at 11:08 AM / IP Logged
Hi,
I have just tried to change the HU in my Audi A2 but have hit a problem.
I am trying to replace the Standard unit with a Pioneer 5100UB.
There does not appear to be any power reaching the HU when I turn the ignition on the unit is dead...when I unplug the ISO connector and plug it back into the factory HU then that works fine!!
I have tried the 5100UB in my partners car and as soon as I connected it to the ISO and switched the ignition on it burst into life.
I am very confused as the HU is obviously ok and the ISO connectors will power the factory HU just fine...
Any ideas? I'm stumped...
Thanks,
Mark
ceasar326
Copper - Posts: 239
Posted: October 07, 2009 at 1:03 PM / IP Logged
Did you use the right harness for the car. Make sure you tied into the right wires. Also whats the brand and model of the harness?
KarTuneMan
Platinum - Posts: 7,056
Posted: October 07, 2009 at 1:06 PM / IP Logged
Ask Howie !
markmorb
Posted: October 07, 2009 at 1:12 PM / IP Logged
Hi,
It's a 2004 Audi A2 1.4SE.
I'm using the following adaptors,etc..
Fascia Adaptor: Autoleads FP 05 04
ISO Harness: Autoleads PC9 404
Aerial Booster: Autoleads PC5 52
Thanks,
Mark
yimke
Copper - Posts: 417
Posted: October 07, 2009 at 4:24 PM / IP Logged
Even though this is hard to do, make sure your plugs are not mixed around. Otherwise you would be pulling your power from a speaker line.
Try switching around your RED / yellow wires. Do you have a multi-meter at all? If so test continuity of the black wire to a ground point in the vehicle.
Unplug the RCA connector for right now.
