c5 corvette
mxxmikexx
Silver - Posts: 796
Posted: March 31, 2003 at 5:18 PM / IP Logged
any pointers in running wires through the firewall and into the trunk on this vehicle?, i've never touched the c5 before and i have a customer who wants a front/rear k40 installed, just wanted some tips before i start, thanks.
x6369x
Copper - Posts: 108
Posted: March 31, 2003 at 6:47 PM / IP Logged
I am in the process of finishing a 2000+ watt system in a 99 C5 Vette using 0 gauge positive and grounds (and yes, the wire is almost as thick as a garden hose). I ended up drilling holes inthe firewall in the passenger footwell area. You have to remove the underdash panel, and look for where the factory loom runs through the firewall and under the hood. You will also have to remove the factory battery, and the wires will be visible from there, just above the area where the Vette's underhood BCM is located.
Friends Don't Let Friends Bump Stock.
