2010 rav4 smart key
mitsu79
Member - Posts: 32
Posted: February 01, 2010 at 6:12 AM / IP Logged
Quick question, i'm install a compustar pro 9000ss, alarm and remote starter on a 2010 toyota Rav4 with a smart key....i just can't research with module to use to bypass the immobilized....
pp
forbidden
Platinum - Posts: 5,354
Posted: February 01, 2010 at 11:50 PM / IP Logged
Are you qualified to install this kind of system in the first place? If so then you would think that you would have contacted Compustar about it and you would have known what bypass module to use..... Do you have the programming tool as well to do the install properly? There is a great module made for this vehicle by idatalink that works quite well with Compustar for that matter. The bypass module needs to be programmed as well...... did I ask you if you had the programming tool and download ability?
If you bought this unit off of some net seller and hope to do it all on your own, good for you. If you want it done with the least possible problems from people with the right tools to install it, find a authorized retailer / installer. The potential to damage a vehicle these days due to improper installation is astronomical. The cost of repairs far outweighs the cost of a proper install.
