1992 camaro box
wadewills
Member - Posts: 32
Posted: March 16, 2010 at 8:20 PM / IP Logged
Hello i have a 1992 Camaro RS and am wanting to install some major bass in it. My idea is to use 2 15's in a vented box. The question i have is if a partial wall is a good idea in this kind of car. Basically the subs would be front firing in a custom box and the port would be rear firing. The other option is forward firing subs and a forward firing port. I am unsure if either of these are a good idea and would greatly appreciate any help with the way the subs and port should fire. Thanks to all
Enjoy Life theres plenty of time to be dead
j.reed
Copper - Posts: 716
Posted: March 16, 2010 at 9:08 PM / IP Logged
fire front port front.
1992 camaro box -- posted image.
wadewills
Member - Posts: 32
Posted: March 17, 2010 at 11:04 AM / IP Logged
Thanks man. I appreciate the help. Does it matter if it is a complete wall or will some gaps between the sides be fine?
Thanks again
j.reed
Copper - Posts: 716
Posted: March 17, 2010 at 12:51 PM / IP Logged
2 15s in a semi wall in that car if in a good, well built enclosure will have no choice but to get loud. Fully walled would give better numbers, but you can do that do that later.
wadewills
Member - Posts: 32
Posted: March 17, 2010 at 2:07 PM / IP Logged
Ok thats exeactly what i needed to know thanks alot!
