'04 nissan 350z bose audio
ijaguar
Posted: July 11, 2010 at 9:56 PM / IP Logged
I have a '04 touring coupe w/bose stero w/o nav and i needed to get a wiring diagram for the wires that go to the head unit no1 seems to have them the only thing ive found says what color wire are what but that doesn't help me if i dont know which prong they go on....thanks
KPierson
Platinum - Posts: 3,527
Posted: July 12, 2010 at 5:46 AM / IP Logged
Start on page 15:
http://www.nicoclub.com/FSM/350Z/coupe/2004.5/av.pdf
Kevin Pierson
ijaguar
Posted: July 13, 2010 at 6:48 PM / IP Logged
That helps some but im not sure where they go in the connector
KPierson
Posted: July 13, 2010 at 8:28 PM / IP Logged
It tells you the colors and pin numbers of every wire on the back of the radio and it shows you the connector numbering. What else do you need? All the info you asked for is in that document.
Kevin Pierson
Thursday, November 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
