steering wheel control and acura tl
six2six
Copper - Posts: 60
Posted: August 11, 2010 at 11:11 PM / IP Logged
Hey guys, hoping I can get some help here. Tried searching and came up with nothing.
I've got a 2003 Acura TL (Type S) with a Kenwood DNX8120. I've also installed PAS SWI-JACK. There are three buttons on the steering wheel, volume up and down along with a channel button (from the factory it changes the radio preset/skips to the next track for cd).
The trouble I'm having is that when I first start the car all the buttons work. After driving for a while, 15 mns or so, only the volume up button works, the other two will no respond. I've ensured I have a solid connection from the adapter to the stereo and ensured it is programmed correctly (since it works when I first start the car.
Any help will be greatly appreciated.
haemphyst
Platinum - Posts: 5,059
Posted: August 12, 2010 at 8:52 AM / IP Logged
My guess? Defective PAC unit... It CAN happen.
Suggest you call PAC technical support. Not trying to shirk the responsibility of answering (since I have jumped in, here...) but it sounds like a manufacturer issue.
Here's the support page... Good luck! I hope you can find your solution.
Saturday, February 21, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
