wire diagram for 2011 ford mustang sync
ocguy106
Member - Posts: 9
Posted: September 28, 2010 at 11:53 AM / IP Logged
Hey all,
Does anyone have the wire diagram for the Ford Sync radio for the 2011 Mustang. I need to know the color for the radio mute and it's polarity.
Ween
Platinum - Posts: 1,368
Posted: September 28, 2010 at 1:32 PM / IP Logged
hi,
i don't see a radio mute lead on the diagrams.  however there is a blue/green at the main radio connector  (pin 7) that is labeled audio enable, and a violet/red at the sub woofer connector (pin 4).  you'll need to test for polarity, believe they are positive though.
mark
ocguy106
Member - Posts: 9
Posted: September 28, 2010 at 2:14 PM / IP Logged
Thank you for the reply...do you have a link or pdf of the wiring diagram, it would be very apreciated.
Ween
Posted: September 28, 2010 at 2:39 PM / IP Logged
sorry, no i don't.
m
bmr4life
Posted: July 03, 2011 at 12:43 PM / IP Logged
Anyone have a link to this diagram? I also have the Nav unit in my 2011 and I need to install a clean sweep or similar device.
stevenstarke
Posted: January 01, 2012 at 3:23 PM / IP Logged
Registered here to post this in case anyone searches and needs it. Here is the wiring diagram.
https://iihs.net/fsm/?dir=710&viewfile=130%20-%20Audio%20System%20and%20Navigation.pdf
Tuesday, March 31, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
