multiple speaker wiring options
pisddub
Posted: October 07, 2010 at 10:47 AM / IP Logged
I have a total of 8 sets of Polk db 6 1/2" 4 ohm speakers that's 16 speakers all together my current setup is for the use of 6 sets I'm trying to achieve a 4 ohm load by using either my current 6 sets or all 8 sets how can I get these 12 or 16 4 ohm svc woofers to 4 ohms thank you
Platinum - Posts: 13,725
Posted: October 07, 2010 at 11:10 AM / IP Logged
Parallel 4 speakes to achieve a 1 ohm load per set.  Do this for the remaining sets of 4.  Then wire each of the 4 speaker sets in series to achieve a 4 ohm load.
afdanw
Copper - Posts: 74
Posted: October 07, 2010 at 11:57 AM / IP Logged
multiple speaker wiring options -- posted image.
should look something like this.
If your cousin is such a good installer, and he will install anything for a 6 pack; why are you talking to me?
afdanw
Copper - Posts: 74
Posted: October 07, 2010 at 12:13 PM / IP Logged
can i ask why?  Why would you want to have 16, full range speakers, on one channel of an amplifier.  Maybe i am assuneing too much, but i would guess you are trying to bridge a single 2 ch amp into 4 ohm on this.  You are talking about a potentially a very big amp needed to do this.  Even if you wanted only 50 watts per speaker, you would need a 800watt amp.  that is the only way i can see you getting enough power out of any amp to correctly push all 16 of those speakers on one channel.  What kind of amp is being put on this?
pisddub
Posted: October 07, 2010 at 2:16 PM / IP Logged
Thanks guys I've been racking my brain on this for a day or two now and my amp will either be a ppi a1200 or soundstream reference 10.0 I'm leaning on using the ppi since all my other amps are arts and I also have a couple of 3sixty.2's as processors
pisddub
Posted: October 07, 2010 at 2:30 PM / IP Logged
FYI you guys are awesome thanks again
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
