combine ports from dual to single
MikeHusain
Copper - Posts: 139
Posted: October 08, 2010 at 2:27 PM / IP Logged
When designing port enclosures, how does one combine 2 ports into one for a common enclosure?  For example if 1 sub needs 1.25 net volume with a 4” diameter port that is 15” long, and i want to build one common enclosure for 2 subs.  Would I need a net volume of 2.5 with a 8” diameter port that is 30” long?  Thanks
DYohn
Platinum - Posts: 10,741
Posted: October 08, 2010 at 7:35 PM / IP Logged
No, ports do not work that way.  You calculate the proper vent size to attain the desired tuning with the net enclosure volume.  So, if your net enclosure size is 2.5 cuft and you want, say, a 30Hz port tuning frequency, build the vent, say, 6" diameter and 29.5" long.  Use the port calculators on this site to help.
MikeHusain
Copper - Posts: 139
Posted: October 11, 2010 at 12:11 PM / IP Logged
I have used the port calculator on this site but it differs from the WinISD program.  For some reason it usuall differs to a 4" port all the time.  Is this accurate.  If i use 12" subs, 10" subs, 1 or 2 subs, the WinISD always recommends a 4" port.  Am i doing something wrong? And correct me if I'm wrong, theres nothing wrong with tuning fairly low (28Hz) is there?  I am trying to obtain the smoothest curve as possible(sound quality) using the WinISD program.  A sealed enclosure in my 05 accord coupe just doesnt seem to give me that low end that I'm looking for.
Thanks for all your help.
icearrow6
Copper - Posts: 497
Posted: October 11, 2010 at 12:58 PM / IP Logged
The tunning of the box is really preference. However 28hz is really low. if you have 10" woofers they will need to have a REALLY high excursion to have a chance at playing that low.
As a general rule of thumb I use a 55hz for 10" 45hz for 12 and 35hz for 15". But its really a preference of the listener.
Also when calculating the port, make sure you take into consideration the displacement of the woofers themselves and any bracing that you have in the enclosure.
So you say the net is 2.5Qft. is that including the woofers already inside?
if your target is strictly 28hz, the displacement of the woofers may change the port's tunning frequency by as much as 5hz.
stevdart
Platinum - Posts: 5,816
Posted: October 12, 2010 at 7:33 PM / IP Logged
The program is not "recommending" a 4" port opening.  That's the default port size...work with the program to suit your needs.
DYohn
Posted: October 13, 2010 at 9:52 AM / IP Logged
https://www.the12volt.com/installbay/forum_posts.asp~TID~74558~PN~1
Sunday, February 8, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
