how to setup this system
jaimieee
Member - Posts: 11
Posted: October 10, 2010 at 4:59 PM / IP Logged
hey i was just wondering how i would configure my setup for this system
i have :
2x sony xplod 12 inch 800W rated 250, 4 ohm
XS L1220
2x song xplod 500w 4/3 channel power amp
XM 5042
Front speakers 4" peak power 130 W rated 30W, 4 ohm
XS GTF1025B
Rear speakers 6" peak power 190 W rated 40w, 4 ohm
XS GTF1625B
many thanks appreciated
jaimieee
Member - Posts: 11
Posted: October 10, 2010 at 5:13 PM / IP Logged
also forgot to add
headunit is Sony iPod/USB/MP3 PlayerCDX-GT590UI
# 52W x 4 Peak power output
# Direct iPod/iPhone control
# Front USB input
# Front auxillary input
# Rear RCA output x 2
i currently have it setup as follows:
2 subs are being powered by one amp, 4 speakers are being powered by the other amp, the rca's from the headunit both run back to the amp powering the 4 speakers. the rear rca splits off and runs to the amp powering the subs. the subs are hooked up to the left and right terminals on the amp, so one sub is running left, and the other is running right
jaimieee
Member - Posts: 11
Posted: October 10, 2010 at 5:24 PM / IP Logged
how to setup this system -- posted image.
Uploaded with ImageShack.us
jaimieee
Member - Posts: 11
this is how one amp is hooked up ^^
jaimieee
Member - Posts: 11
Posted: October 10, 2010 at 5:28 PM / IP Logged
this is how the subs are hooked up
Platinum - Posts: 13,723
Posted: October 10, 2010 at 7:45 PM / IP Logged
What is your question, and are you planning on using the 2 unused channels of the bass amp?
Are the rear channels of the amp also capable of operating a 2 ohm per channel load?  You have min 4 ohms on your diagram.
jaimieee
Member - Posts: 11
Posted: October 11, 2010 at 12:27 AM / IP Logged
my question is how would i set this up correctly, as the way it is setup now, the subs dont sound as good as they did setup in my other car running one sub off each amp
i dont know what your saying sorry, im not technical with this stuff
lol
jaimieee
Member - Posts: 11
Posted: October 11, 2010 at 12:36 AM / IP Logged
i dont know much about stereo's, ive only guessed on how to hook it up, and i was wondering if there is a better way to hook it up or have i done it correctly ?
Posted: October 11, 2010 at 7:50 AM / IP Logged
jaimieee
Member - Posts: 11
Posted: October 11, 2010 at 7:59 AM / IP Logged
what does that mean? sorry im a newb
Thursday, November 13, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
