monoblock amplifiers
knotdrummer88
Copper - Posts: 162
Posted: November 06, 2010 at 12:59 AM / IP Logged
why do monoblocks have two sets of terminals? are they bridged internally? and if wiring one set of wires to them do you run them in one channel or "bridge" the two channels?
Platinum - Posts: 13,723
Posted: November 06, 2010 at 4:54 AM / IP Logged
They use 2 sets of terminals only for ease of installation.  Both positive terminals are electrically connected inside the amp.  Same for both negative terminals.
knotdrummer88
Copper - Posts: 162
Posted: November 07, 2010 at 10:17 AM / IP Logged
so if you put say a two ohm load into each channel internally it will be bridged into a one ohm load in one channel?
Posted: November 07, 2010 at 12:17 PM / IP Logged
There is only one channel.  But yes if you connect 2 separate 2 ohm loads to the amp, since the terminals are internally paralleled, the load on the amp will be 1 ohm.
roadshop570
Copper - Posts: 128
Posted: November 07, 2010 at 8:55 PM / IP Logged
Monoblock amps are usually 2ohm stable only, unless stated D-Class which are 1ohm stable, there is a lot of companies out there now using this heading is a selling tool, just be sure to read what the amp can do, and everything above in the posts are right as well.
Chadillac
Posted: November 07, 2010 at 9:46 PM / IP Logged
There are many class D amplifiers that are not 1 ohm stable.
roadshop570
Copper - Posts: 128
Posted: November 07, 2010 at 9:53 PM / IP Logged
Absolutely correct, there is alot of D-Class amps that are not 1ohm stable, thats why I included the  just be sure to read what the amp can do, line in the post,thx.
Chadillac
knotdrummer88
Copper - Posts: 162
Posted: November 08, 2010 at 1:46 PM / IP Logged
so if an amp is one ohm stable i can put a two ohm load into each set of termials and it will be at one ohm? and also if running just one set of wire do they just go to one or the other set of terminals or do you bridge them?
haemphyst
Platinum - Posts: 5,059
Posted: November 08, 2010 at 11:56 PM / IP Logged
THERE IS NO BRIDGING. Bridging connects two channels of a stereo amplifier to a single individual load, in a mono configuration. You have one channel. You cannot bridge one channel. Just forget that word, for now. They are parallel connections, just done for you inside the amplifier for convenience.
If you have two identical (just for example) 4 ohm woofers, you simply wire one of them to one set of +/- terminals on the amplifier, and you wire the other woofer to the OTHER set of +/- terminals on the amplifier. That is not a bridge, it is a parallel connection, and presents the amplifier a 2-ohm load.
Just parallel. The outputs of the amplifier just has two positive and two negative electrical connections for the installer to connect to.
If you have only one 4-ohm woofer, you can connect it to EITHER set of +/- connections on the amplifier, and be done. This is a 4 ohm load, no matter HOW you mix/match the positive terminals or the negative terminals.
If you have a DVC woofer, you can connect one voice coil to one set of terminals, and the other to the other set of terminals, it's the same thing as doing it on the woofer itself, it just parallels the voice coils.
knotdrummer88
Copper - Posts: 162
Posted: November 09, 2010 at 5:03 PM / IP Logged
ok awsome thank you! let me see if i got this right, so if i have a D2 sub and wired each coil into a set of terminals on an amp the amp would be seeing one ohm right?
Thursday, November 6, 2025 • Copyright © 1999-2025 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
