setting gain using a dmm
newnick
Member - Posts: 10
Posted: November 18, 2010 at 4:15 AM / IP Logged
I'm planning on using a DMM to set the gains on a four channel amp using a test tone.
Is it safe to do this without the speakers hooked up? I'm concerned with turning the power up on the amp without a load on it. I've done alot of reading about this but haven't seen a answer to my question.
The other concern I had is, if I left all the speakers hooked up, and checked one channel at a time would the test tone at high volume damage the speakers?
66sportfury
Copper - Posts: 81
Posted: November 18, 2010 at 3:55 PM / IP Logged
you can have a load on the amp. but there's no need to. it will not damage the amp if you do or if you do not. the test tone shouldn't hurt the speaker no. unless you run the amp into a heavy clip at high power.
ac delco am radio and sparkomatic 40 watt sound exploder
newnick
Member - Posts: 10
Posted: November 18, 2010 at 6:05 PM / IP Logged
Friday, April 24, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
