02 denali, amp
nando21
Member - Posts: 10
Posted: March 15, 2011 at 8:54 PM / IP Logged
hey how r u guys...my name is fernando i have a 02 denali.....i want to hook up a amp to it..... i want to use the factory head unit.... where can i et the remote from? any cable with 12 volts? any tips? thanks
jpadj22
Copper - Posts: 100
Posted: March 16, 2011 at 12:24 PM / IP Logged
You got 2 choices that I know of
1. you can get it from your fuse box from the fuse that says "radio" just strip the wire and tie on to that.
2.Your ignition wire
No better feeling then getting a remote start to work right!
nando21
Member - Posts: 10
Posted: March 16, 2011 at 12:37 PM / IP Logged
Ok thanks so much
soundnsecurity
Gold - Posts: 2,720
Posted: March 17, 2011 at 6:48 PM / IP Logged
i wouldn't use the fuse at the fuse box mainly because it looks so unprofessional. i always go to the ignition harness. on your car you can use the large gauge pink, orange, white, or brown wires. either one will do. the pink and white are true ignitions that stay hot during cranking and the orange and brown wires are accessories which have no power during crank. solder and tape your connection if you can dont use connectors like T-taps because they have a tendency to break strands off of the main wire and they look terrible.
nando21
Member - Posts: 10
Posted: March 17, 2011 at 9:39 PM / IP Logged
Yeah that's what I did I got it from the ignition wire... now the problem is that it sounds like doodie....I used one of does things that converst from the spekers to rca outputs... I plug them to one of the small speakers from the rear of the truck...should I have pluged it ti the factory sub?....or should I just put a aftermarket head unit ?
jpadj22
Copper - Posts: 100
Posted: March 18, 2011 at 9:33 AM / IP Logged
What does it sound like? Do you get engine noise?
nando21
Member - Posts: 10
Posted: March 18, 2011 at 1:47 PM / IP Logged
No it almost sounds like there is voices coming out of the subs like if I had the amp on highs not bass.... but all the amp settings are fine I got tired of it so I just got the dash kit and the wire harness to put in my flip out... but I am still trying to figure it out???
buddholly
Copper - Posts: 244
Posted: March 26, 2011 at 3:08 PM / IP Logged
Sounds like the speaker you tapped in to is crossed over. You will need to either run to the factory sub wires or run to a speaker that gets full-range sound...like the door speakers. Also make sure the amp is set to LPF not HPF or Full.
Tuesday, April 14, 2026 • Copyright © 1999-2026 the12volt.com, All Rights Reserved Privacy Policy & Use of Cookies
