amp choice for cdt components
garretcar
Member - Posts: 23
Posted: May 09, 2011 at 3:26 PM / IP Logged
I've always had great luck here, primarily as a lurker researching questions (to which I usually find an answer in minutes - thanks to the expertise on this forum).  I'm looking now to buy an amp for some CDT EF61 components up front (I believe they are about 110 watts RMS).  .  I have a separate powered sub, so I only need a 2-ch amp for the fronts.   I read through alot of the hot topics and many, many amp posts and am now considering the 5 amps listed below.  Given the wealth of experience on this forum, anyone have an opinion on which of these would be best for the components I have?  Other suggestions for comparable amps are also welcome.  Cost isn't the primary factor for any of these.  I just don't want to go over the cost of the most expensive of these, which is probably the Zapco stuff.   I'm primarily interested in SQ.   Thanks for any opinions.
Alpine PDX-2.150 - Alpine 2 Ch 300 Watt Digital Amplifier
RMS Continuous Power (14.4V, 20-20k Hz)
150 Watts x 2 @ 4 Ohm
150 Watts x 2 @ 2 Ohm
300 Watts x 1 Bridged into 4 Ohm
S/N Ratio : 100dBA
CEA2006 S/N Ratio : 78dBA
Input Impedance : 10k ohms
Frequency Response (+0, -1dB) : 20 - 20k Hz
Input Sensitivity : 0.2 - 4.0V
Class-D 1/2 Channel Operation
Zapco Reference 350.2 2 Ch. 350 Watt Amplifier
Stereo, 4 ohms: 2x100 Watts
Stereo, 2 ohms: 2x175 Watts
Bridged, 4 ohms: 1x350 Watts
T.H.D. + Noise: <0.015%
S/N Ratio: >95dB
Slew Rate: >29V/uS
Damping Factor: >200@4 ohms
Zapco I-2100 -  iForce Series 2 Ch. 350 Watt Amplifier
Stereo, 4 ohms: 2 x 100 Watts
Stereo, 2 0hms: 2 x 175 Watts
Mono, 4 ohms: 1 x 350 Watts
T.H.D. : <0.3%
Frequency Response: 10 - 25KHz
S/N Ratio: >90dB
Channel Separation: >50dB
Audison LRX 2.150 - 2 Ch 220 Watt Amplifier
AMPLIFIER STAGE
Distortion – THD (1kHz):  0.009 %
Bandwidth (-3dB): 4 Hz ÷ 85 kHz
S/N ratio (A weighed @ 1V): . 105 dB
Damping factor (1 kHz, 4 Ohms): 240
Input sensitivity:  0.2 ÷ 5 VRMS
Input impedance: 15kOhms
Nominal output power (RMS)
NP @ 12VDC;THD 0.3%:  70W x 2 (4 Ohms)
Output power (RMS) @ 13.8 VDC;THD 1%
- A config.:  80W x 2 (4 Ohms)
- B config.:  110W x 2 (2 Ohms)
- C config.:  220W x 1 (4 Ohms)
Sundown SAX-125.2 - 125W 2-Channel Amplifier
RMS power, 4 ohm stereo 125W x 2CH
RMS power, 2 ohm stereo 200W x 2CH
RMS power, 4 ohm bridged 400W x 1CH
Signal to Noise Ratio >90dB
Variable Subsonic Filter 10Hz to 500Hz
Frequency Response 10Hz ~ 40KHz (+/-1dB)
THD at RMS Watts <0.1%
Channel Separation 75dB
Input Sensitivity Variable 200mV~6V (+/- 5%)
haemphyst
Platinum - Posts: 5,059
Posted: May 12, 2011 at 2:54 PM / IP Logged
CDT's, huh? While not awful components, the Zapco (especially the Reference) and the Audison would be simply WASTED on those sets... Were you to be driving Brax, or a high-end Morel or Dynaudio set, then by ALL MEANS, use the Zapco or the Audison. Those are the PINNACLE of reference, sound-quality amplification for the car.
My personal recommendation/choice would be the Alpine. I am super happy with mine... Been reliable, and they offer VERY GOOD sound quality for the money.
I can't speak to the Sundown amp, I've always heard good things about them, but I have no personal experience with them.
garretcar
Member - Posts: 23
Posted: May 14, 2011 at 1:21 PM / IP Logged
THanks for the feedback.   I've been happy with the CDTs for some time.  Excellent sound.  But possibly looking to upgrade too.   Care to elaborate on why the Zapco's a "waste" on CDTcomps?  That's a bit of a vague statement.  Can you suggest a good source for Dynaudio components.  You seem to know you stuff around here.  Thanks.
haemphyst
Posted: May 14, 2011 at 2:49 PM / IP Logged
I just mean with the phrase "a waste" that the amplifier far outclasses the drivers you are considering connecting to them. The CDT *is* decent gear, and for the money, there is precious little out there to compare.
As I mentioned, the Zapco Reference is at the pinnacle of sound quality for audio reproduction in the car, where none of the CDT's quite reach that kind of "reference" level. This *is* my opinion, and if you are happy with your choice of the CDTs, then by all means use them. All of the amplifiers you have selected as options are spanktastic gear. I just would (again... "my opinion") mate them to a much higher caliber speaker system.
Now... All of this being said, and all of the concessions therein, I would only use the Zapco amps on full active systems. There are VERY few off-the-shelf "component" systems that I care to hear beyond the sound-board.
http://www.dynaudio.com/relaunch1/car_hifi/products.php
As far as dealers or sources? Unknown for certain... My system is a full active three-way, and hand-selected individual drivers.
I seached google for these keywords:
buy dynaudio car speakers
There were some good looking results there, but there were many that won't be allowed for posting here...
http://www.braxhifi.com/home/
Now... Go look at a REAL passive crossover. Just the pictures on that site will show you the difference between a $300.00 passive system's crossover network, and a $2000.00 passive system's crossover network. The attention to detail, the quality of the components, the physical layout of the devices... All this plays a part in the quality of the sound produced.
garretcar
Member - Posts: 23
Posted: May 14, 2011 at 7:20 PM / IP Logged
Thanks much.   That's a much clearer answer.   I understand where you're coming from.   Thanks again for the comments.
