looking for any info on a concord ceq7
crazybabies
Posted: June 22, 2011 at 4:43 PM / IP Logged
I was wondering if anyone has ever installed a concord ceq7. I was wondering if anyone remembered what size fuses this eq takes or if i can wire it directly to the fuse box. because i remember what wires are what,but cant remember the fuse sizes any help would be greatly appriciated thank you
Platinum - Posts: 13,726
Posted: June 22, 2011 at 7:20 PM / IP Logged
I do not remember which unit that is, but if it has no speaker outputs, use a 3 amp fuse.  If it is the unit with speaker output wires and you are using them, 10 amps.  With speaker wire output, but you are not using them, 5 amp.
crazybabies
Posted: June 23, 2011 at 9:50 AM / IP Logged
This is the model with out the speaker out puts and it has the hot and a memory wire. Do you think i can wire it to my trucks fuse box? if i can find a 2 or 3 amp fuse in the box?
Posted: June 23, 2011 at 10:05 AM / IP Logged
What kind of truck? Usually we would use the Vehicles OEM radio wiring. Are you using a factory radio?
crazybabies
Posted: June 23, 2011 at 11:21 AM / IP Logged
its a 1994 dodge dakota ex cab im using a pioneer p2900mp i forget the last letter or number but its a cd player thats sattalite ready
Posted: June 23, 2011 at 11:29 AM / IP Logged
Constant wire of the EQ to the same connection as the Yellow wire of the radio. Use the radio's Blue/White wire to turn the EQ on only when the deck is powered up. If the radio has only a solid blue wire, use that one. If it has both, use the Blue/White. No need to run any wires to the fusebox.
crazybabies
Posted: June 23, 2011 at 11:35 AM / IP Logged
i figured that much but the eg has a memory wire not a remote turn on
Posted: June 23, 2011 at 3:23 PM / IP Logged
What color are the wires of the EQ? The yellow wire of your radio is the place to get memory for the EQ.
