blown fuse
Streethop03
Posted: May 07, 2003 at 5:36 PM / IP Logged
ok, i dont know if im just dumb or if somthing is really wrong here. Last night i got my amp hooked up and it worked pretty good but it was cluttered in the back of my VAN.   today i decided to clean it up a bit. i disconected the negetive battery terminal, cleaned stuff up , hid wires, disconected and rerouted some stuff and proceeded to connect the negative terminal again. I INSTANTY BLEW THE FUSE ON MY POWER WIRE!!. The power wire is not cut or touching any other wires. someone wanna tell me what happend if they have a clue. Thanks
bberman1
Gold - Posts: 2,314
Posted: May 07, 2003 at 6:26 PM / IP Logged
Could be one of 2 things, 1st one could be you have one of your amps or other components wired incorrectly. Or 2 one of the power cables could have gotten pinched cut or exposed, in the process of cleaning everything up and remounting things. What you need to do is make sure everything is hooked up correctly and that none of the wires are exposed or touching one another.
