tuning my amp?
mantasuk
Posted: March 07, 2013 at 9:16 AM / IP Logged
Hi all. Can you guys help me out to tune my amp?
My amp manual says RMS Power@14.4V, into 2Ohm = 800w so square root formula doesn't mach the car amp manual. If I calculate with the square root I need 40.00V which is three times greater than stated in the manual. Does this formula apply to every amp or is it something I don't understand? Can I apply this square formula rule to calculate other amps or follow manual instructions only? Not every amp provides these settings. Please help! :( Thanks!
DYohn
Platinum - Posts: 10,741
Posted: March 07, 2013 at 6:42 PM / IP Logged
Read the "How to set your gain" thread in the Hot Topics section.
soundnsecurity
Gold - Posts: 2,720
Posted: March 08, 2013 at 8:16 AM / IP Logged
voltage on the input gain does not equal power out. they are independent of each other.
tommy...
Gold - Posts: 1,901
Posted: March 08, 2013 at 8:29 AM / IP Logged
This post was originally in " How to set your Gains"... Pretty sure he is lost...
M.E.C.P & First-Class
oldspark
Gold - Posts: 4,913
Posted: March 08, 2013 at 9:06 AM / IP Logged
mantasuk wrote:
... RMS Power@14.4V into 2Ohm = 800w ... I need 40V which is three times greater than stated in the manual.
That is correct.
The amp has an internal SMPS that converts the input DC voltage to the voltage required for 800W into 2 Ohms.
The power formula is correct. An SMPS is required for amps over ~200W into 1 Ohm, 100W into 2 Ohms, etc.
Oddly enough this same question (with different values) was asked years ago on this forum yet nobody gave that answer. Poor guy, he never returned - though he may have read my PM that explained it to him.
One interesting question - if an amp has an SMPS, why does it have to be 14.4V for max power since the input voltage shouldn't matter - ie, 12V - 14.4V should be capable of max power output.
And if you read the specs on some high output amps, the output increases squarely with the input voltage as if the amp is a resistive load - which it can't be since it has an SMPS...
DYohn
Posted: March 08, 2013 at 9:53 AM / IP Logged
OK, well my advise to the poster, if the info in that thread is too difficult, is to take the system to a local installer and pay them to do it for you. :)
tommy...
Gold - Posts: 1,901
Posted: March 08, 2013 at 10:02 AM / IP Logged
That's a big 10-4...
oldspark
Gold - Posts: 4,913
Posted: March 08, 2013 at 6:37 PM / IP Logged
I can't see anything in How to set your Gains that answers the OP's question. There is mention 30V etc, but not how that relates to 14.4V.
It is a simple question with a simple answer. Soundnsecurity touched on it.
What's the big deal?
wth has this got to do with setting gains?
Why send the OP to an installer to get an answer to his question?
And why insult the OP?
DYohn
Posted: March 08, 2013 at 6:48 PM / IP Logged
The OP's question is about setting gains.
oldspark
Gold - Posts: 4,913
Posted: March 08, 2013 at 7:27 PM / IP Logged
Though it may relate to setting gains, I saw the OP's question(s) as being in relation to Power@14.4V into 2Ohm = 800w & the 40V required, namely:
Does this formula apply to every amp...?
Can I apply this square formula rule to calculate other amps...?
IMO the answer is simple. YES.
It's a case where someone has added a bit of their own analysis and found a contradiction. A case of a little bit of knowledge.... But so what? The same often occurs on the12volt, and not just by the OPs and noobs!
As to the 12V or 14.4V versus 40V output etc versus its impact on setting gains, fine, the other thread addresses that.
But why not solve the OP's dilemma with an appropriate reply first?
I do recall in that earlier thread I referred it seemed no one could answer that. That was back in my early days on the12volt and it did somewhat trouble me at the time.
Simply pointing out that the output was 40V or similar and NOT the 14.4V input would have saved the plethora of irrelevant replies.
(Maybe that was one week before soundnsecurity came on line LOL!)
