fosgate r500x1d amp and 8 inch sub
relentless85
Member - Posts: 11
Posted: November 08, 2013 at 1:55 PM / IP Logged
My friend asked to install a sub in his 2013 GMC Sierra Crew Cab using his stock stereo. He has already purchased a box that fits an 8 inch sub and also purchased a Fosgate R500X1D mono amp. Since he wants an 8 inch sub, do you have any suggestions to what sub we should use. He was looking at a shallow mount RF P1, but will his amp be too much for a P1? I was thinking more on the lines of a Kicker Comp VR or just a Comp.
Here is a link to the amp that he has purchased:
http://www.crutchfield.com/p_575R500X1D/Rockford-Fosgate-R500X1D.html?tp=35834
He wants a setup like mine in my Ford F150 but cheaper. I am running a single 8 inch probox sub, in a ported probox under the rear seat. Its running off of a JL Audio JX500/1D mono amp. I think the probox 8 inch sub can handle up to 450 RMS. I did not install the system in my truck, purchased it with it already installed.
relentless85
Member - Posts: 11
Posted: November 09, 2013 at 10:50 AM / IP Logged
Here is some info on the box:
Measurements
Width: 26"
Front Height: 9"
Back Height: 5"
Depth: 15 3/4"
Airspace: .80 Cu.Ft. Per Chamber
Subwoofer Mounting Depth: 5 1/2"
GMC Sierra Crew Cab Single 8 inch enclosure
Here is the sub he was looking at purchasing:
Rockford Fosgate P3SD4 8
los panda
Member - Posts: 20
Posted: November 09, 2013 at 12:35 PM / IP Logged
http://www.woofersetc.com/p-10522-sa-8-v2-d4-sundown-audio-8-dual-4-ohm-sa-v2-series-subwoofer.aspx
carbonite77
Posted: January 23, 2014 at 6:39 AM / IP Logged
The shallow subwoofers are for trucks with no room for a full size box. If you want a nice 8 inch sub look at the Sundown audio subs. If your just using one then get a 2 ohm 8 inch sub. you will up the power on the Rockford amp. Sundown audio make nice subs for the price.
